Navien, Inc., the leader in condensing technology, is proud to announce that its innovative NPF Hydro-furnace has been selected as a feature finalist for the prestigious ...
Neutra-Safe® Offers System Feeder, Vertical Neutralizer
Neutrasafe Corp., in Rockland, MA, now offers an automatic hydronic and thermal solar system feeder, in addition to their newly-expanded line of condensate neutralizers.
The System Feeder introduces fluid and accurately maintains pressure in closed-loop systems. The easily-installed unit is designed for use with water or glycol solutions of up to 50 percent. A digital pressure control allows individually adjustable cut-in and cut-out pressures points between 1 and 50 PSI, with a secondary pressure switch cut-out at 60 PSI.
The System Feeder’s six-gallon tank is equipped with a set of dry contacts to connect to a remote alarm if the fluid level gets too low, and can be used with a standard 115VAC outlet. Because it features a commercial-grade diaphragm pump with internal check valve, it eliminates need for a PRV and backflow preventer. The System Feeder also limits the amount of fluid that can be lost in the event of a major break.
Neutrasafe now also offers vertical condensate neutralizers. The tube-type neutralizers provide all the benefits of their standard 2-inch models for applications where a horizontal configuration isn’t ideal. Two vertical models serve high-efficiency, gas-fired appliances up to 220 MBH, and feature a stainless screen and media-filled sack for simple recharging. The media-sack recharge kits, which can be used in all 2-inch Neutra-Safe® neutralizers allow for an easier recharge process.
All Neutra-Safe® products are designed by a Master Plumber with more than 30 years in the industry, and are built in the U.S.
Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
