C. C. Controlled Combustion Co. Inc.
2377 Washington Ave, Bronx, NY 10458
Contact: Eric Bendjouya
Phone: (718) 367-9800
Website: http://www.heatingny.com/
Profile
Controlled Combustion is located in Bronx, New York but offers the following commercial heating services in all of NYC including Staten Island, Brooklyn, Queens, and Manhattan. Our experts are dedicated to helping businesses maintain a high-performing team and a conducive working environment. Controlled Combustion has been in business since 1980. We are well-versed with the safety factors, considerations, and governmental code requirements.
Services
Heating Contractor, Heating Maintenance, Install Heating System, Repair Heating System, Ductless Heating and AC Services, Backflow Preventer Testing, Boiler Cleaning, Boiler Inspection, Boiler Maintenance, Boiler Systems Installation, Boilers Work, Burner Installations, Commercial Boiler Repair, Comprehensive Service Contracts, Condensing Boilers, Electric Heat, Emergency Boiler Repair, Emergency Heating Service, Energy Management, Fuel Oil, Heating Oil, Installation & Repair, New Boiler, Oil to Gas Conversion, Plumbing Repair, Pressure Vessels, Prevention Maintenance, Replacement Parts, Safety Inspection, Sewer Lines, Stainless Steel Chimney Liners, Steam Boiler, Storage Tank, Sump Pump Installation, System Inspection, System Upgrades, Utility Room, Water Heater, Water Quality
Gallery
Case Study
Water Main Break in Upper West Side
Challenge
On January 13th at 5am a 3-foot water main broke sending over 500,000 gallons of water rushing down Broadway and turning the streets between West 61st and West 65th into a river.
Approach
NYC & Con Ed Crews worked for over 3 hours to shut off the water but by that time many of the local building’s basement and utility rooms had already been flooded. Once the water had subsided many building owners were left with damaged service equipment including boiler rooms full of dirt and sand and incapable of providing heat and hot water to their tenants.
Solution
Controlled Combustion were contacted by two of the affected buildings to supply and install Mobile Boilers for temporary heat and hot water. Once contracts were signed we sprung into action. Our expeditors worked with our licensed professionals to obtain DOT, DOB Boiler & DOB Electrical Permits for the Mobile Boilers. Our Project Management Team worked on assembling the necessary Field Teams of Electricians, Pipe Fitters, Welders, Technicians and Foremen. Our Foreman surveyed each job to determine the best place to deliver and place each Mobile Boiler as well as how and where to connect to each buildings infrastructure. Our Procurement Team secured the properly sized Mobile Boilers and the necessary pipes, valves, fittings, wiring and ancillary equipment required. Once boots were on the ground the Foremen and Field Teams worked tirelessly against ever changing conditions as the disaster recovery efforts ensued. Our Foremen coordinated with members of Con Edison, NYC DOB Boiler Division and NYC Emergency Response & Intergovernmental Service Division during the entire process. To ensure the tenants don’t face anymore heat and hot water interruptions our Controlled Monitoring System (CMS) is being utilized to ensure proper operation and fast response to failures that might occur with the mobile boilers.
