Scully's Plumbing & Heating
65 Tucker Lane, Malverne, NY 11565
Contact: D. Scully
Phone: (516) 887-1122
Website: http://www.scullysplumbing.com
Profile
Having established Scully’s Plumbing in Malverne over 30 years ago, we know that Nassau County is home to some of the oldest and most complicated plumbing and heating systems. For this reason, we specializing in what most consider a “Lost Art”. Scully’s Plumbing specializes in gravity hot water and steam heating systems. With a little knowledge, you can bring these old systems back into the 21st century! So the next time you see a Scully’s Plumbing truck traveling around Nassau County, take comfort in the fact that, somewhere, a job is being done with the utmost knowledge of plumbing and heating, and a true passion for perfection.
Services
All Phases Of Plumbing - Steam Heating - Hot Water Heating
Gallery
Case Study
Saved SARCO Vapor Heating System
Challenge
The challenge was a steam system that wouldn’t heat properly and hadn’t for many years, 12 at the very least! What we came to find was truly discomforting. Being obsessed with steam, it physically hurt us to look at this system. Nevertheless, the problems had to be fixed. What we found was the distant remnants of a SARCO Vapor System. The alternating receiver, air eliminator, and check valves, the vital organs of this system, were all long gone. Making things worse, the system had NO main vents, once wet returns that were now well above the boiler water line, and cross over steam from the mains into the dry returns.
Approach
So here was our approach in saving this SARCO Vapor System. The first order of business was the main vents, or lack thereof. Without any main vents, the system easily ran at 9.5 lbs of pressure. Along with adequately sized main vents, a vaporstat was required to properly lower the operating pressure. Yet another issue requiring our attention was cross over steam from the mains into the dry returns. The approach here was lowering the dry return connection below the waterline, as the original boiler waterline was much higher then the newer boiler waterline. Finally, the previously high operating pressures cause the boiler to crack, requiring replacement.
Solution
The solution to this challenge was ultimately new main vents, a vaporstat, re-piping dry return lines, and a new properly sized Burnham steam boiler, resulting in one of the happiest customers we've ever had!
