Wilson Services Inc
474 Easthampton Rd, Northampton, MA 01060
Contact: Wilson Services Inc
Phone: (413) 584-3317
Fax: (413) 584-3377
Website: http://www.wilsonph.com
Profile
We are a quality-minded hot water heat and HVAC retrofit shop. Most of our installations are "rebate qualifying" systems, and can offer Zero% financing for high-efficiency AC/Heat Pump installations through Mass Save (please see Mass Save for further information, or contact Gary Wilson as well for specific details). We are very focused on certain aspects of the heating, hot water and cooling trade.We are not well-staffed for certain aspects of the plumbing trade (service calls, sink, toilet, leaky pipes, etc).
Services
Residential HVAC, Boilers, Heat Pumps, Air Conditioning, Duct installations, Service and repair
Gallery
Case Study
Large Renovation Project
Challenge
A 1350 sq ft ranch was undergoing total renovation along with doubling the square footage. Approximately 2750 sq ft of 'in floor' radiant installed with virtually no pipes below the floor joists. Careful consideration was placed into future means of alternative energy usage- as in the "Primary Loop" can accept additional heating plants down the road such as an oil boiler or a geothermal water to water heat pump, or even solar.
Approach
We methodically and diligently planned routes and drilled hundreds of small-diameter holes through the old and new construction to install the new radiant floor heating system, and built the 'wall' that accommodates all of the newly installed (and future) hydronic heat piping
Solution
We chose the Viessmann Vitodens 100 because of its simplicity and durability. The radiant system is operated by Tekmar, so it (the radiant system) is completely independent of the boiler. An 80 gallon Stiebel Eltron water heater was installed to handle the larger mater bathroom whirl-pool tub. Grundfoss Alpha circulators were installed to keep wattage to a minimum, and the Grundfos UP10 was installed to circulate hot water to the original-location bathroom in the original structure
