Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
Agentis Air to Present Study Results on Indoor Air Quality Optimization for Effectiveness and Energy Efficiency at AHR
Air-purification technology company Agentis Air will share the findings from a study on “Optimizing the Use of Room Air Purifiers in Combination with HVAC Filters for IAQ and Energy Efficiency” at the ASHRAE 2024 Winter Conference in Chicago later this month. Part of the ASHRAE Technical Program, the Agentis Air paper will be presented on Tuesday, January 23, 2024, at 12 pm CST in the Great Lakes F Conference Room at the Marriott Marquis Chicago.
The paper explores the relationship between room air purifiers and HVAC filtration and how to optimize indoor air quality while minimizing energy use. The study determines this relationship at a variety of particulate levels, with fine and ultra-fine particles, a variety of HVAC operating conditions (such as air circulation rates and MERV ratings), and a variety of CADR levels for the subject room air purifiers.
The study has added relevance considering the new ASHRAE Standard 241: Control of Infectious Aerosols, which establishes an equivalent clean airflow (ECAi) formula that includes the use of room air purifiers, as a supplement to HVAC systems, to remove fine and ultrafine particle such as viruses and other pathogens. In the face of the serious and wide-ranging threat presented by airborne pathogens and poor indoor air quality, the HVAC-only solution—using higher MERV-rated filters—creates new problems, as these filters have backpressure that often exceeds the capacity of the HVAC systems in which they are installed. Even when compatible, high-backpressure filters also use more energy and require frequent filter changes, making them more expensive to maintain and environmentally unfriendly. As the study indicates, using appropriate room air purifiers in tandem with standard HVAC systems can reduce the energy penalty while achieving ultrafine particle filtration goals.
The company will also demonstrate the underlying Advanced Particle Removal Technology (APARTTM) used in the study, and in their Brio® air purifiers, at the concurrent AHR Expo held at McCormick Place (Booth S9854).
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
Armstrong Fluid Technology announced that they will join other industry-leading organizations in helping create the world’s first 100% digitally-enabled building and rese...
