Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
Armstrong Fluid Technology Introduces its New E Series Pump-Less Volute Kit
Armstrong Fluid Technology has announced the introduction of its E.2 Pump-Less Volute (PLV) kit which is designed to upgrade, renew or replace all working parts of all models in the E Series family of circulators.
The kits are suitable for both hydronic fluid and potable water applications and include all the new features that were introduced with the second generation of the E Series.
The E.2 Series are energy-efficient, Dry Motor circulators designed for a wide range of applications. They include a permanently lubricated mechanical seal that can be replaced quickly and easily. Featuring improved durability and enhanced protection against leakage and water damage to electrical components, the key design elements of the E.2 Series include:
- • New water slinger to protect motor against water intrusion
- Larger, stainless steel shaft
- Sealed, permanently lubricated bearings
- Bellows-style mechanical seal with silicon carbide wear surfaces
The energy-efficient dry motor design and hydraulics of the E.2 Series circulator is rated higher than many other fixed speed circulators in its class, and the wire-to-water efficiency provides more energy savings for building owners. The compact size of the E.2 Series circulators, with minimized flange-to-flange dimensions, makes installation easy and also allows contractors to complete an installation without making changes to existing piping.
Because the new E.2 PLV Kits are also compatible with the original E series, it is now possible to upgrade the older series to the latest E.2 Series technology.
About Armstrong Fluid Technology
With more than 1000 employees worldwide, operating seven manufacturing facilities on three continents, Armstrong Fluid Technology is known around the world as a leader and innovator in design, engineering and manufacturing of integrated solutions within the building oriented fluid-flow equipment industry. Armstrong products are internationally recognized for design innovation, quality, long service life, and superior operating economy. For more information about Armstrong Fluid Technology visit www.armstrongfluidtechnology.com.
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
Armstrong Fluid Technology announced that they will join other industry-leading organizations in helping create the world’s first 100% digitally-enabled building and rese...
