Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Armstrong Fluid Technology has unveiled a new high performance Pressurizing Pump for the Latin American residential market that is designed to increase hydraulic pressure in homes that have dishwashers, high-flow showerheads, water heaters and other high-demand equipment.
Featuring low power consumption and a flow sensor that allows automatic activation, the new Armstrong Pressurizing Pump can supply a home with 1 to 5 bathrooms. It can be installed at the outlet of a water tank or before any supply or derivation to service.
Adaptable to both cold and hot water up to 90°C, the new pump is ideal for instantaneous heaters. It can also be used for ventilation, heating and air conditioning circulation.
The pump activates automatically when a tap is opened and turns off when the tap is closed.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
