Armstrong Fluid Technology has launched a new service to help building operators restore and maintain top performance and efficiency in HVAC systems. The new SMART Recomm...
Armstrong Introduces the Stainless Steel COMPASS R High-Efficiency Circulator
Featuring Advanced Variable Speed Design with ECM Motors
Armstrong Fluid Technology has announced that its next technology evolution COMPASS R20-75 circulator is available in a stainless steel construction.
Designed for use in potable water systems, the new stainless steel model features a dry rotor design, as well as advanced variable speed Design Envelope technology, Armstrong iECMTM motors, and quadratic control to minimize both energy costs and long-term operating costs for homeowners.
The innovative quadratic control algorithm offers operating efficiencies that are better than standard variable speed solutions, and even greater system energy savings are possible with the 0-1V dc input signal connection to external systems.
The COMPASS R is a direct performance replacement for nine competing circulator models and a bolt-to-bolt match for many installed circulators. Other innovative features of the stainless steel COMPASS R circulator include:
- Optimized hydraulics with a high-efficiency dry rotor design
- “Posi-start” technology provides smooth starting and automatic de-blocking
- Onboard control panel for easy selection of the appropriate operations mode and flow
- Release latch for easy adjustment of the display orientation and repairability
- Easy-to-access front-facing terminal block with a large wiring chamber
- Replaceable mechanical seal, and any other circulator part required
- Complies with EEI<0.22, NSF-372
Navien, Inc., the leader in condensing technology, is proud to announce that its innovative NPF Hydro-furnace has been selected as a feature finalist for the prestigious ...
Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
