Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Caleffi Hydronic Solutions' popular 132 Series QUICKSETTER™ static balancing valve line has been expanded. The new flanged QUICKSETTER is used to balance fluid flow in hydronic heating or cooling distribution branch piping systems. The valve has ANSI 125 cast iron flanges for pipe sizes 2½”, 3” and 4” with adjustable flow ranges of 30 to 105 GPM, 38 to 148 GPM and 55 to 210 GPM respectively. An integral flowmeter with industry exclusive, nonwetted flow scale permits fast and easy circuit balancing without the need for differential pressure gauges and charts. A smooth hand wheel movement allows for high adjustment accuracy. The rotation indicator has a tamper resistance lock. The valve is cooling and heating rated from 14° to 230°F (-10° to 110 °C) and is glycol compatible (up to 50% concentration). Flowmeter isolation valves protect meter from debris and facilitate ease of meter removal and service.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
