Quilt, a leading innovator in smart home climate technology, today announced an evolution in its business with the introduction of its Certified Partner Program, a collab...
Bosch Thermotechnology introduces the next generation of its premium air-source heat pump system – the Inverter Ducted Split (IDS) 2.0 system, offering a 20-plus seasonal energy efficiency ratio (SEER) inverter drive that precisely matches the heating/cooling load for greater efficiency.
The full IDS 2.0 product range is ENERGY STAR compliant and provides whisper-quiet operation – as low as 56 decibels. The accompanying air handler includes a two-stage x13 electronically commutated motor (ECM) blower for enhanced humidity control and an all-aluminum coil for superior corrosion resistance.
With a heating seasonal performance rating (HSPF) of 10.5 and heating operation down to temperatures of four degrees below zero, this heat pump yields highly efficient operation, even in cold-climate applications.
“As we continue to expand our air-conditioning portfolio, we’re thinking about what’s important for both our customers and contractors,” said Katie Woodling, product manager at Bosch Thermotechnology. “The IDS 2.0 is a next-level product that has it all: greater efficiency and better performance for customers, and easier serviceability and simplified control board maintenance for contractors.’”
The inverter compressor offers 25% to 110% capacity with modulation in 1% increments. The unit’s compact footprint allows for easy installation and is compatible with most standard 24 VAC heat pump thermostats.
The Bosch IDS 2.0 outdoor unit can integrate with Bosch’s 96% AFUE gas furnace and cased coils for an exceptionally efficient dual heating and cooling system.
Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
