Bosch Home Comfort, a leading source of high-quality heating, cooling and hot water systems, is unlocking a new product category with the market launch of its latest inno...
Coffee with Caleffi™ Hot Water Recirculation Systems Thursday, July 20 12 noon CDT
There’s more to designing a domestic hot water (DHW) recirculation system than just adding another pipe and circulator. John Siegenthaler, P.E., a favorite guest speaker to the webinar series, will describe the objectives and benefits of recirculating DHW systems including simple single loop systems, and multi-branch systems. He will explain the concept of temperature-based flow control in recirculation systems, and thermal balancing. John will conclude by showing an example of how unique products such as the Caleffi ThermoSetter™ valve provide intelligent, safe, and energy efficient operation of multi-branch recirculation systems.
You'll learn:
→ What are the benefits of domestic hot water recirculation systems?
→ What can happens in domestic hot water systems that do not have recirculation provisions?
→ How should plumbing designers determine flow rates in a domestic hot water recirculation system?
→ What are the advantages of temperature-based control of recirculating domestic hot water systems?
→ How can a variable speed circulator be used in a domestic hot water recirculating system?
A seasoned industry leader and visionary, John shares his over 35 years’ experience in the understanding and proper application of water-based engineering principles and passion for teaching with our audience. He is a regular contributor to industry publications Plumbing and Mechanical, PM Engineer and HPAC magazines.
Coffee with Caleffi™ technical training webinars are free and intended for contractors, designers and wholesalers. Register by clicking the link below and following the instructions. After registering, you will be immediately forwarded a confirming e-mail containing log-in details for attending the webinar.
When training time comes, grab a coffee and learn more about Caleffi’s innovative products and how they can add value to your work. All attendees are emailed a Certificate of Attendance following the event.
By submitting your webinar registration, you are consenting to email communications to keep you up-to-date on industry news. Please note that your personal information is respected and NOT shared externally.
The first annual John Hazen White III Memorial Tribute was held under sunny skies on Saturday, April 27, at Narragansett Brewery. It was a memorable day filled with unity...
Carbon reduction policy is now the norm for the Northeastern States. Renewable low-carbon and zero-carbon energy sources are being aggressively pursued. Among them, solar...
