Navien, Inc., the leader in condensing technology, is proud to announce that its innovative NPF Hydro-furnace has been selected as a feature finalist for the prestigious ...
Commercial Vertical Electric Power Water Heaters from Bradford White, Niles Steel Tank and Laars Heating Systems
Bradford White Corporation subsidiaries, Bradford White Water Heaters, Niles Steel Tank, and Laars Heating Systems now offer 150- to 2,500-gallon electric water heaters, from 12 to 162 kW that feature 150 psi ASME code glass lining, ASME temperature and PRV, internal fusing (above 120 amps) and magnesium anode rods.
Bradford White’s Product Marketing Manager, Chad Sanborn, said that developing the improved large volume commercial electric water heater was an integrated effort. “For the past several years, we leveraged broad resources within the corporation. These products are an example of our multiple engineering teams working together to develop an enhanced and cost-effective solution for large volume, electric applications.”
The water heaters also offer immersion thermostats, manual reset high limit, hinged and locking door and channel iron skid base. The water heaters are used in hospitals, apartments, dormitories, commercial laundry facilities and in areas with low gas availability. The water heaters also come with a three-year limited tank warranty.
This new large volume water heater complements Bradford White’s ElectriFlex Series™ of light duty, medium duty, and heavy duty field convertible models, to offer customers a wide range of commercial electric water heating solutions.
Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
