Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
EVAPCO’s AT Atlas counterflow cooling towers are designed in large, preassembled modules for ease of rigging and installation. As the most energy efficient modular cooling tower on the market, the AT Atlas is unmatched in CTI-certified capacity per cell.
The Atlas’ modular concept and superior performance are ideally suited to projects at or above 4,000 tons. Atlas systems require fewer cells to achieve high cooling capacities, reducing the need for piping and electrical connections by up to 50%.
Atlas series cooling towers range in capacity from 1,484 to 2,386 nominal tons per cell – providing up to 60% more cooling capacity per cell, while requiring up to 40% less fan power per ton of cooling – when compared to traditional factory assembled cooling towers.
Available in Type 304 or Type 316 stainless steel – including the entire basin, support structure, vertical columns, louver frames and plenum. Site installation supervision is available from factory-trained technicians.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
