Bosch Home Comfort, a leading source of high-quality heating, cooling and hot water systems, is unlocking a new product category with the market launch of its latest inno...
Expandable Grundfos Hydronic Zone Controls Manage Any Size Residential Heating Application
The expandable Grundfos UPZC series of zone controls manage circulator and boiler control in residential hydronic heating systems. The non-networked devices control up to six heating zones and can be coupled together in various configurations to accommodate any application. Boiler pumps, domestic hot water pumps, system pumps and pump priority are all controlled from the UPZC control.
The zone relay control connects to standard thermostats using either two or three wires. The optional third wire provides 24VAC to thermostats that require external power. The UPZC operates in a cold start configuration with a call-for-heat from a thermostat. The module’s relay is energized which, in turn, switches 120VAC to activate the circulator and also provides a call-for-heat signal to the boiler.
Side-mounted terminals provide simple access and wiring, while the forward facing, easy-to-read LED display on the front panel shows system status and zone function.
All models are UL-listed in the United States and Canada and carry a three-year warranty.
The first annual John Hazen White III Memorial Tribute was held under sunny skies on Saturday, April 27, at Narragansett Brewery. It was a memorable day filled with unity...
Carbon reduction policy is now the norm for the Northeastern States. Renewable low-carbon and zero-carbon energy sources are being aggressively pursued. Among them, solar...
