Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Fresh-Aire UV®, Jupiter, Fla., a leading manufacturer of indoor air quality (IAQ) products, introduces the Purity Low Profile LED (PLP-LED) the HVAC industry’s first one-inch-thick (24-mm) replaceable filter that combines biological contaminant disinfection, VOC removal and particulate capture. The PLP-LED offers high efficiency filtration with minimal static pressure loss and is designed to fit the most common one-inch filtration rack sizes in residential and commercial air handlers.
The PLP-LED is the 2020 Air Conditioning Heating and Refrigeration (AHR) Expo Innovation Award winner in the IAQ category. Fresh-Aire UV also won the same award in 2011 for its APCO® combination UV, carbon-media and photocatalytic oxidation air purifier.
The PLP-LED is a three-stage filter using mini LED light arrays, advanced photocatalytic-coated reactive chemical adsorption media, and polarization technology to disinfect biological contaminants, remove VOCs and collect particulates, respectively.
The PLD-LED consists of three filter layers held together inside a corrosion-resistant, latched aluminum framework/mesh grill clamshell. The top and bottom blue layers are a particulate-capturing, UV reactive fiberglass media treated with Nanotech™ antimicrobial and photocatalytic coatings. They’re sandwiched between a black carbon core for improved VOC removal. The frame’s grill, which includes two UV LED disinfecting arrays, opens easily for quick media replacement every four to six months. The PLP-LED also employs low-voltage negative and positive polarization to charge, attract, impinge and agglomerate particulates into the fiberglass media.
The three stages are:
The PLP-LED performance can be enhanced with an optional installation of a Fresh-Aire UV’s renowned Blue-Tube UV® or APCO system for keeping the evaporator coil, air handler interior surfaces and airstream free of mold and other biological contaminants. Other PLP-LED features include:
Fresh-Aire UV has been a leader in biological and VOC removal for nearly 20 years; now the third segment of IAQ–particulate collection–gives a comprehensive air cleaning option for residential and commercial spaces.
The PLP-LED will be available at most HVAC wholesale distributors in the first quarter of 2020.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
