Navien, Inc., the leader in condensing technology, is proud to announce that its innovative NPF Hydro-furnace has been selected as a feature finalist for the prestigious ...
Modine’s Enhanced Geothermal Heat Pumps
Modine’s geothermal systems now offer an enhanced control platform. The robust controller has served the manufacturer’s school systems and commercial ventilation product lines for more than a decade.
All Modine geothermal systems – from 1.5 tons to 12 tons – now feature the proven Modine Control System, providing quick start-up, easy safety device wiring, multiple inputs and outputs, BACnet IP/Eth, BACnet MSTP and Lon capability and easy troubleshooting.
The ENERGY STAR-rated residential and light commercial geothermal product line includes water-to-water, water-to-air, water-to-air/water combination, and split condensing/air-handling systems; all use R410A refrigerant.
Standard features include ECM fan motors, dual speed scroll compressors, MERV 13 air filters, oversized heat exchangers and a 10-year limited warranty.
- Water-to-water residential and light commercial models are available in reversible and non-reversible sizes from 2- to 12-ton sizes.
- Water-to-air models range in size from 1.5- to 6-ton units in both vertical and horizontal configurations. Compact commercial systems are also available for water source or geothermal applications.
- Water-to-air/water combination units provide forced air heating and cooling and also the ability to provide heat for radiant-heated floors, domestic hot water, pools/spas and snow melting. They are available in 3- to 6-tons in both vertical and horizontal configuration.
- Split system/air-handling systems, from 2- to 6-tons, are well-suited for new and retrofit applications.
Modine offers a number of options including a desuperheater which provides supplemental domestic hot water; cupronickel heat exchangers for applications where harsh water conditions exist; tin-plated coils to eliminate formicary corrosion; and electric heating for auxiliary back-up heat.
Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
