Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Navien, Inc., the number one brand in high efficiency condensing combi-boilers and wall-hung boilers in North America, has started shipping their new lines of fire tube boilers and combi-boilers. The NFB-H condensing fire tube boilers and NFC-H condensing fire tube combi-boilers were first introduced by Navien during their Boiler Virtual Launch Event on February 16, 2021.
Navien’s upgraded NFB-H high-output condensing fire tube boilers are available in two sizes, NFB-175H and NFB-200H. Both models include Navien’s patented stainless steel fire tube heat exchanger with a non-metallic condensate drain pan. The combustion chamber is form pressed to resist corrosion and the heat exchanger is robotic laser welded to ensure the highest quality with repeated results. New high-efficiency features on the NFB-H include turndown ratios up to 15:1, powered connections for 3 zone pumps or 3 zone reduce areas valves, easy to use Setup Wizard for improved installation, 2" venting up to 65' and 3" venting up to 150'.
NFC-H high-output condensing fire tube combi-boilers are also available in two models, NFC-250/175H and NFC-250/200H. The NFC-H also offers Navien’s patented stainless steel fire tube heat exchanger along with a built-in DHW module that includes a flat plate heat exchanger. New advanced features on the NFC-H include turndown ratios up to 15:1, powered connections for 3 zone pumps or 3 zone valves, easy to use Setup Wizard for improved installation, 2" venting up to 65' and 3" venting up to 150'. The NFC-H also includes increased DHW performance with up to 210,000 BTU/H for DHW, offering up to 5.4 GPM at a 70-degree temperature rise.
For more information on both the NFB-H and NFC-H fire tube products visit navieninc.com.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
