Neutra-Safe® Expands, Improves Condensate Neutralizer Line
Neutrasafe ALL Products Grouping Final
Rockland, MA-based Neutrasafe Corp. has added new products to their line of high-quality condensate neutralizers to fit almost any hi-efficiency, gas fired application.
Improvements have also been made to all tube-type and tank-type neutralizers, enhancing ease of maintenance and/or performance.
Tube-type condensate neutralizers are now offered in four sizes from 220,000 to 2 million BTUH. Addition of the largest size now fills the gap between the company’s 1.2 million BTUH tube-type unit and the smallest tank-type neutralizer. Tank configurations are available with capacity guidelines of 4 million and 6 million BTUH.
The new patent pending tube-type neutralizers feature integral unions with O-ring seals that greatly simplify removal for service and recharging. Unclasping a lock ring on either end of the unit allows the main body to be removed without disturbing the drain line. Replacement O-rings are included with tube model recharge kits and all tube model neutralizers are available with a snap-in mounting clamp option. The new model was designed by a Master Plumber with more than 30 years in the industry and is completely manufactured in the US.
Along with Neutra-Safe’s upgraded and expanded product line, the neutralization media for all units has been improved. A mix of calcite and magnesium oxide pellets is now used for enhanced performance and is also available in recharge kits for any of Neutra-Safe’s condensate neutralizers.
