Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Thermal Solutions AMP-L condensing boiler and water heater is available in five sizes: 400, 500, 650, 800 and 1000 MBH. AHRI Certified and rated at 97% and 98% thermal efficiency respectively, the AMP-L is available in either a natural gas or propane configuration.
Standard AMP-L models save time and simplify planning. Included at no additional cost are the low water cutoff and high and low gas pressure switch making the AMP-L CSD-1 compliant. Also equipped standard with a strength-adding 3-in-1 vent connector which allows for the use of polypropylene, CPVC or stainless steel venting. AMP-L is capable of up to 200 equivalent feet of vent in AL29-4C, polypropylene or CPVC. Modbus communication also comes standard.
Measuring only 27” wide, the AMP-L easily fits through most doorways and is easily maneuverable in the boiler room. AMP-L stacks two-high without the need for accessory racking systems. Zero side and top clearance optimizes the amount of BTUs AMP-L can offer per square foot.
In addition to standard 10:1 turndown, impressive 300 gpm flow rates and the self-cleaning nature provided by the commercial grade water tube design, an outdoor model is also available at no additional charge.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
