Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Two residential models, with maximum inputs of 165,000 and 199,900 Btu/h, offer dual, stainless-steel heat exchangers with category-best, 15-year warranty.
New from Noritz America, the NRCR Residential Condensing Tankless Water Heater Series uses a fully integrated pump to keep hot water close to even the farthest outlet in the home, minimizing the wait and, therefore, the waste of unused potable water down the drain. The Auto Mode on the new NRCR quickly learns household water usage and automatically triggers recirculation-loop activation in line with that expected usage. The correct water temperature is delivered quickly when and where occupants need it the most.
Available with inputs of 165,000 Btu per hour and 199,900 Btu/h, the new NRCR series delivers a premium solution to meet the growing demand for hot-water recirculation. Both models carry an ultra-high Uniform Energy Factor (UEF) of 0.97, while offering the superior durability of dual, stainless-steel heat exchangers. The corrosion and heat-shock resistance of this high-grade material permits an industry-leading, 15-year warranty.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
