Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Oatey Co. today announced the launch of the Fix-it Repair Ring™, which securely repairs broken, cracked or worn-out toilet mounting flanges without replacing the toilet flange.
Built with a robust design for installation strength, the Fix-It Repair Ring features a sleek, unobtrusive profile. It’s conveniently compatible with all flange and toilet installations, as well as flooring types (including concrete). Plus, 10 mounting holes and four slotted mounting tabs further enable a wide range of installation options.
The Fix-It Repair Ring is built for installer ease and reliability, including a perfect-length bolt slot that prevents bending during installation and provides secure, level, leak-free repairs. It can accommodate 1/4-inch or 5/16-inch closet bolts. Because of the thicker wall span between the bolt slot and the ring perimeter, weak points are minimized.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
