Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
REHAU Launches New Weather-Sensing Control Option for Automated, Cost-Effective Management of its Hydronic Snow and Ice Melting Systems
REHAU announces the launch of an advanced new weather-sensing control module developed for use with REHAU hydronic snow and ice melting (SIM) systems. The REHAU Smart Controls SIM Module also features an automated option that allows the system to operate with optimum efficiency.
REHAU’s innovative hydronic SIM system is designed to quickly and efficiently remove snow and ice from vehicle or pedestrian pathways. SIM systems minimize snow removal and accompanying costs, as well as the need to apply salt or other melting agents that can be corrosive to outdoor surfaces and detrimental to the environment. Installed underneath or embedded within an outdoor surface such as concrete, asphalt or paving stones, the system includes RAUPEX® pipe, the EVERLOC® compression-sleeve fitting system and PRO-BALANCE® manifolds.
The SIM controls module employs the unique ability to “listen” to the weather forecast via web-enabled access to the National Weather Service (NOAA) and Environment Canada. Using the weather data and temperature sensors installed within the melting area, the control chooses an automatic idle temperature setting to warm the slab so that melting begins at the first sign of snow or ice. To save energy, the control turns the system off once the surface is dry.
“The REHAU hydronic SIM system combined with our Smart Controls SIM module provides a sensible alternative to the annual expense and complication of manual snow and ice removal,” said Ollie Carman, applications engineer at REHAU. “In comparison, operating costs are usually much lower while the ability to effortlessly maintain safer outdoor surfaces during winter provides unparalleled convenience.”
The SIM control module’s web-enabled feature also allows the system to be controlled remotely from any internet-accessible device. In addition, the module is flexible, scalable and programmed to meet a range of requirements including unlimited snow melting zones and priority scheduling to clear crucial areas such as walkways and entrances first. The SIM module can be used independently or integrated with a REHAU Smart Controls indoor comfort control system.
For additional information, contact: REHAU, 1501 Edwards Ferry Rd., N.E., Leesburg, Va., 20176. Phone: 1.800.247.9445. Fax: 1.800.627.3428. E-mail. Web site: http://na.rehau.com/simcontrols.
REHAU delivers “Unlimited Polymer Solutions,” and is the premium worldwide brand for polymer-based innovations and systems in construction, automotive and industry. The company generates continuous growth through its expertise and innovative capabilities in materials development, systems design and surface technology. Approximately 18,000 employees at more than 170 locations around the world ensure success of the independent, privately held company.
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
Armstrong Fluid Technology announced that they will join other industry-leading organizations in helping create the world’s first 100% digitally-enabled building and rese...
