Navien, Inc., the leader in condensing technology, is proud to announce that its innovative NPF Hydro-furnace has been selected as a feature finalist for the prestigious ...
Taco Offers PF Series Plate & Frame Heat Exchangers
Taco Comfort Solutions’ PF Series plate & frame heat exchangers are ASME designed and constructed. Computerized product selection greatly simplifies the process of choosing the correct heat exchanger for the required application. The compact size of PF Series heat exchangers, along with ease of servicing and Taco dependability, make it an ideal choice for a wide range of commercial applications.
Models with operating pressures of both 150 and 300 psi are available. With flow rates from 50 to 7,000 GPM, PF Series heat exchangers are capable of handling a wide variety of system requirements. Connection sizes from one- to 20-inches are available, with glue free, clip- and snap-on nitrile or EPDM gaskets.
An aluminum or optional 304 stainless steel OSHA shroud are available. Many different applications are possible, including economizer free cooling, ground source heat pumps and freeze protection isolation, campus heating and cooling and pressure zone isolation.
For more information, visit www.TacoComfort.com.
Armstrong Fluid Technology announced that Kilmer Environmental is the new representative for northern central Ontario. With a highly knowledgeable and experienced team co...
On October 24, U.S. Boiler Company hosted a Hops & Heat learning event at Trillium Brewing Company in Canton, MA. This is the second event of its kind U.S.
