Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Targeted for specific U.S. regional distribution partners, Uponor is launching TotalFit™ — the professional-grade, engineered polymer (EP), push-to-connect fitting solution that provides greater value for residential projects with the same versatility and speed as brass push-to-connect fittings.
Designed for use with PEX, PE-RT, CPVC, and copper piping systems, TotalFit is ideal for service repair, maintenance, remodels, and retrofits for potable hot-water and cold-water distribution piping systems in single-family homes, townhomes, apartments, and condominiums.
“Uponor has a strong leadership position in residential plumbing with AquaPEX® pipe and the ProPEX® fitting system,” says Aaron Stotko, director, Segment Marketing, at Uponor. “Now, with TotalFit, we are expanding into the plumbing repair, maintenance, and renovation segments with a high-quality, reliable fitting solution from a brand professionals trust.”
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
