Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
It is with great excitement that Warmup® announces that the much-awaited Peel-and-Stick version of the DCM-PRO Membrane floor heating system is coming to North America. The TCNA-tested membrane is the first of its kind and adheres directly onto plywood and concrete subfloors without the use of thinset. Launched in the UK, France and Germany in 2016, it has been successfully tested to ANSI 118.12 anti-fracture standards and the Robinson test (ASTM C-627). Combined with the DCM-PRO cable, it is the only UL-approved membrane system on the market today.
Why a Peel-and-Stick Back?
The patented DCM-PRO Peel-and-Stick System is making top-of-the-line floor heating accessible to all installers. The Warmup® DCM-PRO design has gained popularity in its first year with a fleece-backed version, delivering warmer floors, faster. The DCM-PRO design allows higher heating outputs and for more adhesive-to-cable contact. This allows heat to distribute faster and more evenly through the floor. In addition, the design also offers protection from installation damage, reducing the risk of cable failure.
The popular benefits of our fleece-backed Membrane led to the innovation of the DCM-PRO Peel-and-Stick Membrane. The polyethylene adhesive will bond to subfloors with 140 lbs of torque/sqft leading to 40% savings in time and materials. Simply cut the membrane to size, peel back the protective film, press the membrane directly onto the subfloor, and fit the cable in!
The use of modified or unmodified adhesives over the membrane is the installers’ choice to best suit their installation needs. The DCM-PRO Peel-and-Stick Membrane can also be covered with self-levelling mortars (SLU’s) to allow installation of small format tiles and other floor types such as glue-down wood and LVT’s. There is no waiting required after installation so you can begin laying flooring immediately. The DCM-PRO Membrane is ready to tile.
Warmup’s DCM-PRO System can be found in retail locations across North America. To learn more about the DCM-PRO Peel-and-Stick Membrane visit our website and come see it first at TISE / Surfaces in Las Vegas, January 21-25, 2019.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
