Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
As part of celebrating National Backflow Prevention Day, August 16, Watts has announced the addition of the ArmorTek™ advanced coating system to its ductile iron backflow preventer valves. This advanced patent pending technology provides three layers of protection to create an effective barrier, dramatically increasing resistance to corrosion.
ArmorTek provides an advanced primer, which contains an electrochemical corrosion inhibitor. It significantly slows the spread of corrosion should the metal substrate become exposed from wear or impact.
ArmorTek’s exclusive formulation also inhibits the growth of bacteria that cause microbial-induced corrosion or MIC. This further slows the spread of corrosion and limits the growth of tubercles that can clog or foul downstream equipment. In addition, ArmorTek’s top layer is specially designed to bond to the primer below, providing a high-strength barrier between the iron substrate and water.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
