Samsung is proud to announce that its Hylex™ heat pump system has been named Green Builder Media’s Sustainable Product of the Year for HVAC. This prestigious recognition ...
Samsung will bring the innovative Wind-Free™ wall-mounted air conditioner to the North American market following the huge success of its floor-standing Wind-Free™ air conditioner in South Korea. The innovative heat pump has integrated Samsung’s exclusive Wind-Free™ cooling technology into its design; providing customers with a cooler indoor climate and optimal energy efficiency without the discomfort of direct cold airflow.
The AR9500M provides customers with the ideal condition by maintaining the desired room temperature, using Wind-Free™ Cooling to gently disperse cold air through 21,000 micro air holes. A two-step cooling system, which first lowers temperatures in Fast Cooling Mode, automatically switches to Wind-Free™ Cooling Mode creating still air* once the desired temperature is reached. This approach can also reduce energy consumption by up to 72%** compared to Fast Cooling Mode.
Using Samsung’s new Digital Inverter 8-Pole with POWERboost technology, the motor of the Wind-Free™ wall-mounted unit generates fewer torque fluctuations, reducing the overall energy required and shortening the time needed for the compressor to reach its maximum speed.
The unit is also WiFi enabled so it can be controlled from anywhere through Samsung’s Smart Home app. Users can remotely regulate temperature, adjust settings, receive real time updates about performance and daily energy usage, as well as troubleshoot solutions when a repair is needed.
The unique triangle architecture has a wider inlet, which allows more air to be drawn in at once, while the optimal width and angle of the outlet, extra v-blades, and large fan (22% larger than previous models) ensure air is cooled and expelled faster, farther, and wider to reach every corner of the room.
To learn more about Samsung residential products, visit www.samsunghvac.com.
Taco is excited to announce its participation at Data Center World 2025, taking place April 14-17 at the Walter E. Washington Convention Center in Washington, D.C. Taco w...
Navien kicked off its USA and Canada Roadshow on March 27, 2025 at Brewery X in Anaheim, California. The event showcased a suite of groundbreaking HVAC products, includin...
