Here is the original Installation and Operating Instructions and Parts List for The H.B. Smith Company's Oil Fired Cast Iron Hot Water Boilers (No. OHB-13W). This is esti...
1927 Proposal for a Mouat Vapor Heating System
Thanks to Gerry Gill for sharing this Mouat Vapor Heating System proposal from the early days of steam heating. Note the nine-ounce setting on the relief valve. You don't need high pressure to heat a building.
Comments by Vanilla
H.B. Smith Company Oil Fired Cast Iron Hot Water Boilers (1972)
Heating the Henry Ford Museum
The Henry Ford Museum in Dearborn, MI has an interesting hot-water heating system. Take a look at the radiators below. They are from the Shaw-Perkins Manufacturing Compan...
The Peerless Heater Company Catalog
We estimate that this cast-iron boiler catalog from The Peerless Heater Company in Boyertown, PA is from the 1980s or 1990s.
