Boiler Room Detective Webinar
During this entertaining and informative one-hour webinar, you will be a famous detective uncovering clues about boiler operation, efficiency, and safety. Industry expert Ray Wohlfarth will help you solve the following mysteries:
- How to be sure the boiler room is safe Can the boiler breathe?
- What boiler noises should raise a red flag?
- How a tissue can help diagnose system problems
- What’s stored in the boiler room and is it dangerous?
- What does rust on top of the water heater mean?
- Why is carbon monoxide dangerous?
- How does combustion air affect boiler operation?
- What is the leading cause of boiler accidents?
- What pressure should we see on the boiler pressure gauge?
- What does a discolored boiler jacket indicate?
Would you like to learn more from Ray? Check out his seminars and books.
Comments by Vanilla
Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
Do Radiator Reflectors Work?
