This all-technical, three-hour seminar will make you familiar with the many types of old steam heating systems and what goes wrong with them. Dan Holohan’s easy-to-follow explanations will have you seeing inside these old systems. You’ll be a much better troubleshooter after this one. If you have to deal with America’s older steam systems, you’re going to love this course.
We'll look closely at:
- Steam radiation of all kinds
- Steam-heating loads
- Boiler ratings
- Proper near-boiler piping
- The importance of water quality
- All sorts of system piping
- The value of pipe insulation
- Pressure-reducing valves
- Steam-to-water heat exchangers
- Balancing systems with properly sized air vents
- Curing water hammer once and for all
- Getting the water back into the boiler
- Pressure settings
- Steam traps
You'll leave this class with a solid overview of steam heating as it applies to older buildings of all sizes.
