Classic Hydronics Seminar
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as he gives you a better understanding of how things work, what goes wrong with them, and why. He’ll share with you the secrets he’s picked up from the Old-Timers and he’ll make you a better troubleshooter.
We'll look closely at:
- The critical importance of pressure differential
- Gravity hot water heating
- Pumping
- Radiation
- One-pipe loops
- One-pipe primary-secondary systems
- Diverter tees
- Two-pipe direct- and reverse-return
- Two-pipe primary-secondary
- Multiple boiler systems
- Two-temperature systems
- Air problems and their solutions (once and for all)
- Classic radiant
And more!
Comments by Vanilla
Do Radiator Reflectors Work?
Circulators or Zone Valves
Adventures in Pumping
