In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
In this excerpt from his Classic Hydronics seminar, Dan Holohan explains how primary-secondary pumping works in a one-pipe hot water heating system. Dan talks about valves, circulators, flow rate, pressure drop, blending temperatures, and more.
Want to learn more? Read Dan Holohan’s book Classic Hydronics: How to Get the Most From Those Older Hot-Water Heating Systems.
