In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
Dan Holohan talks about applying the concept of Pumping Away on a one-boiler hot-water heating system. He’ll walk you through a diagram and explain how Pumping Away will help you stop air from getting into your radiators.
Want to learn more? Read Dan Holohan’s book Classic Hydronics: How to Get the Most From Those Older Hot-Water Heating Systems.
