In this presentation, Gary Klein shares important information about air source heat pump water heaters (HPWH), with particular attention paid to where the warm air comes ...
The Best Place to Install a Cast-Iron Radiator
Q: If I decide to move a cast-iron radiator, where should I reinstall it?
A: Ideally, a cast-iron radiator should be under the window (that’s where the greatest heat loss is), and it should be as wide as the window. Its top should never peek above the windowsill because this lessens the convective movement of air around the radiator. Speaking of which, for maximum convective efficiency, the radiator should be 2-1/2 inches away from the wall. It took the old-timers years to figure that out.
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
