In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
Two-Pipe Hot Water Heating Systems
In this excerpt from his Classic Hydronics seminar, Dan Holohan shares his knowledge on two-pipe hot water heating systems. He talks about the advantages of two-pipe systems, direct return, reverse return, direct return with thermostatic radiator valves (TRVs), differential pressure regulators, hydronic heating flow rates, tips on sizing circulators for existing jobs, and more.
Want to learn more? Read Dan Holohan’s book Classic Hydronics: How to Get the Most From Those Older Hot-Water Heating Systems.
