What to Do with Boilers During the Summer
Not many people graduate from Harvard at the age of 20 but Theodore Minot (who, understandably, went by T.M.) Clark did. Mr. Clark was born in Boston in 1845, the same year that The New York Herald first mentioned a new game called baseball. He went on to be the editor of American Architect magazine and he also was in charge of the Department of Architecture at M.I.T. for a good long time. He wrote several books and served as a director of the Workingman’s Building Association, which helped poor people buy homes so they could have a stake in America. Today, the Workingman’s Building Association is called the Boston Foundation. Nice.
Mr. Clark has been dead for many years but he continues to be a fascinating conversationalist because he left behind delicious books and articles. He continues to share, and he really knows his stuff.
I was thinking about how we’ve grown so used to central heating, and with the exception of an occasional cleaning, pretty much ignore our boilers and heating systems when the weather gets hot and sticky. I wondered if it had always been thus, and who better to ask than T.M. Clark, the workingman’s architect. So I did.
D.H. Mr. Clark, I’ve been reading your stuff and smiling at how much you know about hot-water and steam heating. These days, most architects leave those mechanical details to the engineers, but I know it was different in your time. Did you do anything special with a hot-water boiler during the summertime?
T.M.C. Well, Dan, in leaving hot-water heating apparatus to take care of itself for the summer, one thing is of great importance – not to change the water. Furnace men and heating contractors generally advise their customers to change the water in every hot-water apparatus at least once a year and “fill them up with nice clean water.” This advice should not be followed for the very good reason that every filling causing renewed rusting and pitting of the inside of the pipes and boiler, which is avoided by not changing the water.
D.H. It’s funny how some things never change. I’ve met contractors who still make that recommendation, even after nearly 100 years. One guy told me there’s a difference between summer water and winter water and you have to change with the seasons. I asked him why that was. He shook his head sadly and rolled his eyes, like I’m stupid for asking.
T.M.C He does not know so well as he should, and ordinary people do not know at all, the difference, in its effect on iron pipes, of fresh water from that which has been heated nearly to the boiling point. The difference is that the latter does not rust iron, while the former does. Unless water is contaminated with chemicals, any effect that it may have in rusting iron is due to carbonic acid gas, and perhaps to ordinary air, dissolved in it. All water, by standing, absorbs air and carbonic acid from the atmosphere and becomes corrosive; but by heating nearly to the boiling point, these gases are drawn out again, and the water becomes non-corrosive.
D.H. So that black, nasty water in a hot-water system is like fine wine, eh?
T.M.C. Exactly! In hot-water heating apparatus, the fresh water first put in loses its corrosive quality as soon as it has once been heated. And so long as that water remains in the pipes and boiler, it continues non-corrosive, except so far as it may be, during the period of disuse in summer, absorb air and carbonic acid from the small amount of surface exposed in the expansion tank. Thus, although the water, after years of use, becomes discolored, the color does it no harm, and such water will have no injurious effect on the apparatus, while fresh water will immediately begin a corrosive action, which will continue until the air in it has exhausted its power for harm.
D.H. These days, we use closed compression tanks, which make things a lot easier for us. I know you guys used those tanks at the tops of your systems that were always open to the atmosphere. It’s one of the things that made hot-water heating safer than steam heating. An open system won’t explode. But what did you do if you had to drain the system for repair? Didn’t that open the system to further corrosion?
T.M.C. Well, there’s a right way and a wrong way. The proper way to it is, before drawing off the old water, pour a pint or so of oil on the surface of the water in the expansion tank, which is always to be found at the highest point in the system. Lard oil or lubricating oil should be used. Kerosene is of little or no use. After you put on the oil, you may draw off the water by opening the stopcock at the lowest part of the boiler or other apparatus. As the water runs out, the oil will follow it down through the pipes and radiators, coating the inside of them with a slight film, which will protect them from being attacked by the moist air left in the pipes, a corrosive agent as powerful as fresh water itself. Refill the system through the expansion tank and immediately build a fire in the boiler, no matter what temperature the air in the house may be, so as to boil the air and carbonic acid out of the fresh water.
D.H. You’ll have to watch out for that oil if the boiler has rubber gaskets between its sections. But those gaskets won’t show up until you’re long gone.
T.M.C. Excuse me?
D.H. Never mind. Hey, before we run out of space here, let me ask you about steam systems and summertime. Should we be treating them the same way we treat hot-water systems and keep using the same boiler water year after year?
T.M.C. No, steam house-heating systems, unlike hot-water heating systems, should have the water drawn or blown off at the beginning of summer, for the reason that the small quantity of war in a steam boiler absorbs air, and gives off dampness, both of which will corrode the pipes and boiler, while, in a hot-water apparatus, there is little absorption of air, and the water, with which the whole system is filled, acts as a protection.
D.H. Well, that certainly got my attention. I know very few people who drain their steam boilers during the summer. Most use the boiler all year for both heating and for making domestic hot water. They just turn down the temperature during the summer so the water won’t boil, but now you have me thinking about all the moisture that’s rising up within the pipes and mixing with air to create rust all summer long. Maybe that’s why the water in a steam boiler usually goes from clear to nasty-red during the first week of firing each fall. And that has folks draining the boiler, which adds more oxygen, which causes more corrosion.
T.M.C. We knew not to do that in my day.
D.H. Lots to think about here, Mr. Clark. Thanks for taking the time to chat.
T.M.C. My pleasure! Hardly anyone talks to me anymore.
D.H. The pleasure is all mine. Oh, and just so you know, you’re going to die in 1909. That’s also the year that the Red Sox will trade Cy Young to Cleveland.
T.M.C. Are they out of their minds?
D.H. And when you’re in the grave for ten years they’re going to trade Babe Ruth to the Yankees.
T.M.C. Babe who?
D.H. It all works out, though. It just going to take some time. Sort of like learning this trade.
T.M.C. Indeed.
In this all-technical three-hour seminar, Dan Holohan will give you a Liberal Arts education in those Classic Hydronics systems. He’ll have you seeing inside the pipes as...
